So ive upgraded from the stock turbo to gt3071 with all supporting mods, but im curious.. can I put a 2" pipe from turbo to intercooler without much/any loss??
Its the hot pipe, which is charged most of the time, so pressure/air mass is prevalent; only after the intercooler on the cold side is the pressure drop/ psi&air mass/density is really taken into consideration?!
I have 2.5" (as i think most of us do; standard) on my cold pipe, and originally 2.5" hot side.. but now with a slightly different setup it might be easier to run the 2" pipe instead of the 2.5"
The turbo has a 2" outlet, therefor designed with a pressurized pipe of equal/greater size to go afterward. Will a 2" hotpipe hinder, improve, or not effect my system!?
Anyone try different size intercooler piping??
Any info/personal exp/comments welcome!!!!!!!!!!!!
