Use a 'T'?I am wondering if I remove my oil pressure sending unit (to connect my aftermarket gauge) will I get a warning message. If yes, is there a way around that? Same questions for a coolant temp gauge.
I want accurate readings.I don't know but it's probably better to just get an OBD gauge with screen.
What's not accurate with OBD readings? They report the car's own sensor values.I want accurate readings.
The sensors can be wrong.What's not accurate with OBD readings? They report the car's own sensor values.
Why don't you just disconnect the sensors and see what happens? Even if you don't get warning messages your engine isn't going to run properly without the ECU knowing the coolant temperature.I am wondering if I remove my oil pressure sending unit (to connect my aftermarket gauge) will I get a warning message. If yes, is there a way around that? Same questions for a coolant temp gauge.
Excellent point!!Why don't you just disconnect the sensors and see what happens? Even if you don't get warning messages your engine isn't going to run properly without the ECU knowing the coolant temperature.
