pluto316 said:What are the widest wheels you have put on your cars? I am looking to squeeze Rota Slipstream 15's on my car with as much width as possible. Think I'll ever fit 8 up front?
xelderx said:Depends on ride height and tire size. Running a 15" rim gives you more room to play, but anything wider than a 225 series tire will probably not fit in the fender well. You also need to consider that the wider rim/tire setup you go with will also be increasing you rotational/unsprung wieght and actually hurt performance. I'm going to run a 15x7 w/ 225 series tires this season for AutoX as soon as I can afford the new wheels.
pluto316 said:I was looking at going wider than 7 because I have that now.. Oh well, I guess that's life? Once my (TERRIBLE PURCHASE, STUPID) Nitto NeoGens run out I am getting new wheels and tires.
xelderx said:Remember that when you drop to a 15 inch wheel you are going to be getting tires that have a much taller sidewall than what you are used to. Depending on the tires this is going to give you a lot more traction than a low profile tire of the same width because of deflection in the sidewall. I think you are going to be doing more harm than good and run into bigger fitment problems trying to stick more than a 225 series tire on a 7 or 7.5 inch rim.
pluto316 said:So you're saying I SHOULDN'T weld two wheels togther to make 14" wide super duely tires?
Damn it.
madmerv said:Are you sure that a 15 will clear the brake calipers on an MSP????
Merv (drive)
xelderx said:Yea...just barely.
nate0123 said:I've seen RX-8 rims on protege5's ... and those are 18x8 (right?)
