WIDEBAND Groupbuy
So here is the list
1-Beavis
2-Kooldino
3-Perfworks
4-duMb KeoLa
5-1st MP3 in NH
I will keep you all updated via this thread. I am hoping to place the order before the weekend. Once I need deposits I will let you all know.
I plan on installing mine in my downpipe where my primary O2 sensor is now...and then moving my primary O2 to the bung where my secondary O2 is NOW, and moving the secondary O2 into a new bung behind the cat.
Damn thats complicated j/k:D
paulmp3 said:
also will i be able to hook this up before i get my turbo?? or do i need a new o2 bung or can i just remove the stock one and put this one in?
yeah im in too. it might be a cool toy to have for future use also;)
tell me when you need the deposit.
oh and can somebody answer my first question.
Is this stil available Terry, Id be interested as well, i can exchange this for the other guage instead - make up the difference?
Ed
TERRY, is this o2 sensor gonna fit in the weld in bung for the stock o2 sensor? the one that comes on your downpipe, if not, does it come with the pieces to be welded to the downpipe or do we have to search for it? just trying to be prepared. thanks
It should fi in the bung ike tghe ones in our downpipe.....it does not come with a bung however.
So here is the updated list.
1-Beavis
2-Kooldino
3-Perfworks
4-duMb KeoLa
5-1st MP3 in NH
6-paulmp3
What the question?:)
i might be in, either that or the greddy air fuel gauge. Im still deciding if it is worth the extra $$.
The wideband is ideal. Check out the write up on the greddy gauge and base your decison from there. Its a great device and we have them in stock:D
sorry, thats my ?? Can i just hook everything up, and put it in the factory o2 sensors spot? and just leave the fatory o2 sensor hanging?
You can hook this up before getting the turbo. You HAVE to keep your stock one in place, you won't be able to just let it hang (someone can correct me on this, as I know some people have had some luck, but I haven't). I'm guessing that the readings would be messed up if you used the O2 sensor after the cat, so it has to be the first one and I don't know if anyone has ever tried removing that one. So you will need to add a bung. Any muffler shop should be able to do this for you.
(The bung will be a couple bucks plus the "time and labor" to drill a hole and weld it in place.)
I would think it would be best to just up the cost of the widebands and send them along too as everyone that gets the wide band will need the bung.
Honestly i don't see a need to up the cost...the bungs cost like 25 cents or so.
Then I don't see he issue to not just include one in the first place so that everyone doesn't have to go out scavanging for one.
Ok I have it all setup.
I will need a deposit from everybody on the list.
of $250.
I expect to recieve the units within a couple of days after that and then he second half of the deposit will be due.
A quick breakdown,
$499 for the unit, this includes shipping to your door
Thanks everyone:D
