I'm not sure about the hub bore size of the Evo VIII, so you'll want to make sure that is at least 67.1 mm. If it's bigger, you'd need the appropriate adapters to reduce their effective size to 67.1 mm. Also, you'll almost definitely need to roll your fenders with that setup.
Thanks for the quick reply. Could you specify which parameters of the setup I'm imagining would cause it to rub? (e.g. tires too wide, incorrect offset, etc.)
It sounds like it might be more of a hassle than it's worth...
