cycoutMSP03.5
- 2003.5 Blazin' Yellow Mazdaspeed Protege
flashed like a mother ******!
why wouldn't cha?
later
ry
(boobs) mmmm boobies!
why wouldn't cha?
later
ry
Because the flash was an easy out fix that advanced timing. Too much timing advance on high boost cars is a factor in detonation. Id rather run 12psi of boost and not worry about detonation.cycoutMSP03.5 said:flashed like a mother ******!
why wouldn't cha?
flashed? unflashed? did i miss something(boom08)TX Speed Demon said:Unflashed - stock boost
Hmmm I am at 12 and have been for some time however, your milage may very as well as your ability to run higher boost without the dreaded hand grenade effect! BE WARNED!!! YOU ******!!! BE WARNED!!!KyRaceFan said:Because the flash was an easy out fix that advanced timing. Too much timing advance on high boost cars is a factor in detonation. Id rather run 12psi of boost and not worry about detonation.
Well thats the mags for ya. The other mag picked up power go figure (dunno)Supraru said:I read in the new sport compact car that they did a test before and after the flash and lost 1 or 2 hp and gained a little less then 1 ft lb of tourque. That kinda sucks. Why would they do that?
No man, didn't mean to give the impression I was flashed than got unflashed by some magical means.DiscreetSpeed said:flashed? unflashed? did i miss something(boom08)
cool, thanks manKyRaceFan said:Because the flash was an easy out fix that advanced timing. Too much timing advance on high boost cars is a factor in detonation. Id rather run 12psi of boost and not worry about detonation.
