alonso.lpez
hello all.
im having a problem with my mazda protege 97.
when i start up the engine in the morning a lot of white smoke come out from the exhaust.
the mechanic said it might be the valves seals, cam shaft seal, egr valve gasket, head gasket, intake manifold gasket, throttle body gasket, valve cover gasket, water outlet gasket, water pump gasket , but the smoke keeps coming out.
is there something else i can check?
thanks
thanks
