which fuse for map lights and keyless entry?
p0wn
I am trying to figure out which fuse(s) i need to replace to get my keyless entry and map lights to work. They stopped working after my head unit was stolen. I have replaced the radio fuse and electrical taped the exposed wires so nothing can short. Is there any other fuses i need to replace? Both map lights and keyless entry are still not working :(
I have the same problem except my stock in dash CD changer doesn't work either. I have no idea what's going on.
#8 ROOM is suppose to be for INTERIOR LIGHTS ETC.
#8 interior lights etc.
#11 DOOR LOCKS
if not those it might be the one in engine compartment called #8 BTN.
Here is what I found out for our fuses
Here is what I found out for our fuses.
1) The book is FU**** wrong.
2) I had to check each fuse with multimeter and indivially turn each device on.
3) I could not find where some fuses went.
4) Some fuses don't have any power what so ever.
5) I show also when there is power.
1. -?---------------------------------------------RUN
2. -?---------------------------------------------ACC
3. -RADIO + MIRROR-----------------------------ACC
4. -BLOWER + MOON + DEFROST-----------------RUN
5. -REAR WIPER---------------------------------RUN
6. -?-------------------------------------------DEAD
7. -?-------------------------------------------RUN
8. -LIGHTS + RADIO + BEEP WARNINGS----------BATT
9. -?-------------------------------------------DEAD
10.-?-------------------------------------------RUN
11.-Door locks----------------------------------BATT
12.-?-------------------------------------------BATT
13.-WIPER + SPRAY-----------------------------RUN
14.-ENGINE-------------------------------------RUN
15.-GAUGES------------------------------------RUN
16.-?------------------------------------------BATT
17.-Power Windows-----------------------------RUN
(dance)
Here's what i found out: The 'room' fuse protects alot of the cars power features: keyless entry, map lights, trip tach memory, the blinker turning off after you turn. etc.
fixed
