Which brand and type of fuel to feed your CX-5 (Canada)
Brand and type of fuel that you uses on the CX-5
  • 87 octane
    Votes: 17 85.0%
  • 89 octane
    Votes: 1 5.0%
  • 91 octane
    Votes: 0 0.0%
  • 94 octane
    Votes: 2 10.0%
  • Total voters
    20
  • Poll closed .
phil_chan86
2014 Mazda CX-5 GS
Hi All,
I used Esso 87 for the past 7 years now. Recently I have couple friends told me that I should switch to Petro-canada. They said Petro fuel burn clearly and good for L/KM. Also they said NEVER NEVER use Shell. Can you share your exp. with all brand fuel company???
(breakn) Your input will be greatly appreciated (breakn)
Sorry i am too new to the forum. How can i edit the vote system??? I need to add the Brand to vote (help)
Seem i can't edit the vote please leave which brand of fuel you are using.
Esso
Petro-canada
Shell
Super Store
Husky
Costco
Not sure if you can edit a vote thread like that. As for fuel, Im not currently brand loyal I just chase the highest octane
I usually go to co-op(have a membership) or Shell. But I'm not brand loyal either. Always 87.
for a while I was getting shell, chevron, or Texaco only. I recently started getting Murphy USA (walmart) and other cheaper gas and my mpg went down so I stopped.
In canada, almost anything I go is "top tier" gas: Petro-canada, esso, or shell. Very rarely do I not find these big names and go to something cheaper.
so Shell give low l/km? I had only 3 fill ups so far and all with Shell. May be I should try something different and see if there is a real difference
I keep very accurate fuel consumption records over the years and have never measured any difference in mileage between Shell, Mobil, Texaco and Murphy, Hess or any other gas. I think it is in the mind of the user that one is better than another and just too many variables. JMO. Ed
There was a time back in the early 2000's where Shell had to pay for damaged fuel sending units on customer's vehicles due to damage that an additive caused. The vehicle would indicate a higher level of fuel remaining while the tank was in fact empty. As for Esso in Canada, they took longer than the others to get their sulphur content in line with CDN standards, This caused cars to stink of rotten eggs if driven multiple short distances. Both conditions above have been corrected.
I manage a fleet of several thousand vehicles and we do not see these problems anymore, however I typically make it a point to drive past Esso, due to how they handled the Valdese oil leak in Alaska where they ruined thousand of lives and appelled the ruling to pay higher compensation to those that lost their livelihoods. The actually pay out would have been less than one day's profit had they adhered to the ruling.
As for using higher Octane, I recall a bulletin that came out on the 2000 MPV. It advised against the use of 92 octane when 87 was required. It caused a "hard start" condition. To better understand octane, the higher the fuel octane, the greater the compression needed to ignite the fuel. If your vehicle is designed to use 87 octane, it will spark at the designated compression. As 92 is less volatile, the 87 spark will be too soon and you will not get the required detonation to provide power and to burn all the 92 fuel in the chamber. In a nutshell, on todays cars, you are wasting your money on 92 octane unless it is specified. In our fleet, drivers buy 92 octane to get double reward miles at the pump. Our fuel card provider send alerts to fleet management when "super" is purchased. Each time the driver swiped a rewards card to get the extra points causing more cost to the bottom line. Needless to say, big brother gets on them ASAP. There is no benefit to a 87 octane vehicle other than making the fuel companies richer and doubling the reward miles.
always use 87.
I switch between esso, petro can, and costco... depending on price and which one is closest when I have to fill up.
2.0 Sport auto measured with G-tech
0-60 8.5 seconds with 87 octane
0-60 8.5 seconds with 93 octane and same gas mileage as 87
You be the judge.
Not brand loyal. With only 155 horsepower why bother!
