Is is form or function for you?
First off, upgrading your fuel system will mean you will raise your boost.
A blow-off valve VTA on a stock ECU motor will richen the A/F Ratio each time you shift. That is why many people don't change to the BOV on the stock ecu. Its not like it will kill the car or anything but anything under 20 psi, the stock bypass will hold just fine. Its known as the ricer mod. more of a sound mod than anything else. Once you do your bolt-ons, Fuel, and EMS tune, then you can have your car custome tuned so it won't run rich during shifts.
But then again, you can get the BOV now and run it in re-circulation until you get a tune.
Remember that on any car, Running too rich or lean is not a good sign at all. Especially boosted cars.
I would say to do the BOV when all is said and done and run it VTA for the sexy sound. Then you will have some power to back up your sound.
hope this helps
