Where can I get replacement bushings for front and rear sway bar?
2008 Mazda5 GT
Hello.
I have a front and rear sway bar from a 2007 MS3. I want to put them on but would like to replace the bushings in the process. Does anyone know where I can get them (not looking for OEM replacements)? I can't seem to find ES or Moog parts that are MS3 specific... Do I have to go universal? Anyone replaced theirs or have input? A link to a source/supplier would be appreciated.
Thanks.
AutoZone, or your local favorite parts store to the rescue!!
They typically carry replacement "greasable" bushings in polyethylene for around $20/set. You will have to do the English to metric conversion however.
I broke a bracket on the 22mm bar I was running and found that it came w/7/8" bushing from the factory. Measure the bars you have and do a google for a conversion chart. Be sure to use silicon grease for poly bushings though as regular dino grease will destroy them eventually.
