Yeah, that too but if you have passengers, for sure rub.Ummm the widest I've seen so far is 17x9.5 ET38 255/40/17
How much fender rolling involved on these bad boys..if there not sold by end of october which im sure they will..Ill buy em.
all i had was my rear fenders rolled...not even all the way, just mild roll
i also had cobb rsb...everything else was stock on my car
absolutely NO RUBBING what so ever...yes thats right, no rubbing
the only time was when I hit a NASTY dip going REAL fast...of course, there shouldn't be any reason you should be going fast on streets with nasty dips like that....so you will not have to worry about anything
whats the widest wheel tire combo can I run without rub on a ms3? id like to run 245 or 255 tires..what size wheel&offset would I need?
He had a mild fender roll and no passengers.This is from the user with the above mentioned wheel/tire combo.
Understand..and thats what i thought with the 235 45 tire..just making sure. I want to have as much tire patch as I can without rubbing and hopefully with out fender rolling..so thinking of going with 18x8 from rota with 48mm offset or tsw trackstar 18x8 with 50 offset..then run a 235/40/18 tire and hope for the best lol.
