Wheel Hop
maxchao,
Hey man it's not a problem, ask away. The mount is really not all that hard to do. There is basicly only three nuts to worry about. Now I would mention that I do not have the stock intake in the way, so that might make it a lil more work, but not by much.
bolts = are long and have threads
nuts = are like hexagonal doughnuts
remove mount
1.) place floor jack under oil pan and jack it up to hold the motor. Make sure
to put a piece of wood on the jack as not to damage the oil pan.
2.) remove the two nuts holding the mount to the chassis
3.) remove the nut holding the bolt through the mount. This is the bolt that connects the mount to the motor
4.) remove bolt going through mount
5.) remove mount
I would mention having a breaker bar will help most likely.
The stock mount has the two fixed bolts that stick out in the bottom for the two nuts. In the SLS provided mount these bolts are not fixed. So if you have any resistance when putting the bolts on, they will spin. It is not easy to get a wrench or socket on the top of the bolts and to keep them their! This is why I have had the bolts welded to the mount, to make it more like stock or AWR. So yes, with the bolts that go through the metal mount (not the part that connects with the engine) you can remove the mount.
I am not sure what the problem is with SLS compared to AWR or SU, but they are all fine units. AWR is nice because you do not have have anything to welded, but I prefer the SLS because of less vibration.
Remember, the idea is to take the slop out the front mount so the engine does not move as far. When you do this you lose isolation from the engine vibration. So it's a balance on how much comfort you are willing to give up for responsiness. AWR has stiff materials used and thus make your car vibrate alot during idle (or so I have read). SLS barely vibrates at idle, but I get better response. I am building my car for everyday and occasional autoX. If your going all track, why not get the AWR? You could do the rear mount, but it is a pain to change! Not only that, but with a good front mount, the engine movement is greatly reduced. If you put a rear mount on, it would give it marginal improvements and increase vibration.
Labor for getting the welding done will depend on the shop and their prices.
I was charged $34 for the job (boy do I wish I had a welder, I could have done it myself).
As for the stock mount, it's all about engineering meets marketing. Everyone makes there mount out of rubber to help with vibration. They can not make it solid, because it probably would vibrate way too much for there target buyers. A good example of this is the stock intake. They have resonators on them to quiet them down. Tuners like performance and sound out of there engines which is against what most regular econo sedan buyers want (quiet). So we open it up, and thus make it louder.
The problem with the stock mount is not the design of the mount itself but the rubber pattern inside. After awhile the rubber will break down (normal), and with the design that connects the center to the outer rubber part will rip/break (thin). Both my passenger and front mount where ripped at 100K miles.
I fully trust in the front mount from SLS, it just needs the bolts welded to make install way easier for you. $68+34+shipping.
I am still not sure about the passenger side mount. The original plate that comes with it broke. They have sent me a replacement steel piece. The only design thing, I am not sure of is the non use of the side brace. It's like a bigger version of the front mount with a plate that is held by a bolt. The engine bolts to the plate. But unlike the stock mount, there is no brace to spread the load. I have not made up my mind whether to have a piece welded to the top, so I can use the brace, or not. I figured out now, that it should help when I am cornering and keep the engine from moving side to side. Of course SLS does not have a tranny mount yet, so I might just go with inserts for the sides. As of now, the side SLS mount is not installed yet. Maybe this weekend?
Of note, when my engine was out the car, the rear mount was good!
As for tire inflation, are you checking after you took the car out or after it has been sitting for awhile? The cold temps I would suggest 32-36 psi. I run 36psi for daily for gas mileage. For autoXing I use 32 psi.
Remember, that when you start driving your car, the temperature of the tires go up and heats the air. This will rise the psi in the tires, thus why I asked you the question above.
I would imagine that the reduced engine movement would also reduce the tranny movement helping with clutch engagement. Though I would think a worn out clutch would cause chatter because it is having problems getting a grip on top of tranny movement.
Magus
AWR > SLS
Im sorry but the design of the SLS mounts is not very well done. Im running a SU front mount and love it.
Did you see a nice improvement with that SU mount? I know it's a softer duro than either the SLS or any of the AWRs...I don't want to rattle my fillings out, but I do want the improved throttle response...
MazdaSpeeder
Just to mention that with the SLS it vibrates so little, it's almost stock! So, if SLS is not going to rock your fillings, I highly doubt SU will do so with a softer duro. I would mention, that I have not put the SLS side mount back on, which does add vibration.
As to the response on the SU vs. SLS/AWR in terms of responsiviness I could not mention. But anything has to be better than stock!
I do have question, what are you guys talking about when you mention"22v" ? Does he have turbo or something?
Magus
JC-MP5
I did a bit more reading and found this from theMan (very knowledgable)
theMan is quoted as saying:
"dude, bad motor mounts are NOT going to cause a clutch chatter/shudder
I've driven cars with holes in the motor mounts and it didn't shake like hell on take off... the motor did rock a whole lot but that's a completely different story
I know you want to dismiss this bad news, but reality is, the clutch and flywheel is bad and that is the only way it'll ever get fixed."
Sorry for the bad news.
Magus
Nice write up Magus! I guess I would try to do it myself, if I can find a floor jack from a friend. :D
Well, I saw theMan's post on changing the flywheel and the clutch too, and I'm sure he's the real expert, but the problem I have here might be that I can't tell if it's wheel hop or clutch shudder. One 'might' relate to the mount and one relate solely on the clutch. Or maybe I have both...And I have some drivetrain lash as first two gear as well...
Well, I think as of my car's age 88k I might have to change the mount pretty soon anyway, so I will try the mounts first.
I will check the tire pressure as well.
and I need to pass the final exams...
Josh
MazdaSpeeder
Magus
I have heard plenty of good things about the SLS, but I can't get the failures out of the back of my mind...I know they weren't all front mounts and that they have "fixed" the problem (more than once) but I am willing to sacrifice vibes for a mount that doesn't fail...I know it can be made well, but the AWR and SU mounts are so much better designed...I guess I just trust them to be more reliable. I was going to go AWR front mount and side inserts, but if it will cut down my vibes a bit I might go SU front mount and AWR side inserts...I just want to get rid of my drivetrain lash!
Josh
I agree with Josh and I think I have the same issue. Is pulling the motor mount the only way to tell if the motor mount needs to be replaced? There's gotta be a better way right?
I'd rather not to spend $100+ on motor mounts if I'm not completely sure that'll fix the problem.
Can someone explain in more detail how a worn out engine mount would cause wheel hop? I can see how the engine mounts would only affect the interior vibrations but in terms of the engine, shouldn't the suspension soak it up?
JC-MP5
Magus
Thanks, but shudder wasnt my concern. It rarely does that, unless I make a momentary error in my footwork. I was talking about how I seemingly get wheel hop too easily. Unless they're linked problems? Nice write-ups BTW.
'I think' the reason that motor mount can cause wheel hop is b/c "oscillation". It's like there is a sweet spot that make the engine bounce around in its bay due to soft or bad mounts and right frequency. (resonance?) It's worse on FWD car since at high forward acceleration the weigh moves toward the back. Something like that...
I checked my tire pressure, it was at 32 psi (It drops kinda fast...), it's pretty much a set of new tires on the front.
Also, there are two durometer for AWR motor mounts, 88 or 95. We are talking about this right?
http://www.awrracing.com/store/product_info.php?products_id=41
Has anyone tried the 88? Maybe it makes less vib and if there is still room for more vib the inserts can be used.
Or maybe I'll just do SLS front and AWR sides...:D
maxchao,
I see you are doing your research about FWD and drive train lash. Here is a helpful quote from Kansei:
"I ran the 95 duro AWR, then back to stock. Then to the 70duro AWR front, then added RR racing rear inserts (AWFUL, AWFUL vibrations), then to the RR racing rear with an SLS Performance front, and now just the SLS Performance front. The SLS is 75 duro but vibrates less than any AWR I've had.. but yeah, with the rear insert and the front mount I had some bad driveline lash still, so I checked my passenger-side mount.. sure enough, it's totally torn through."
I would point out that I am currently running a "new" stock passenger side mount. When I was replacing the stock mounts (front and side) with SLS I noticed they were ripped and threw them out (should have kept the side mount to maybe get part of the mount ripped off). So after reading that quote, I might replace the side mount and check the vibration. If the vibration is not too high, I will probably kept it installed. I was running the side mount when I was doing the autoX and I believe it helped. I was only a second down from a RX-8, 350Z, and two seconds down on a C6 auto. These where my mods:
Mazda Protege5' 02 ATX (non sport, but I can shift to all gears, so no big difference)
-SLS front and side mounts
-mx-6 strut bar
-Progressive 22mm rear sway bar
-AWR adjustable read endlinks
-X3 CAI (like Injen) w/ AEM bypass
-BFG Traction T/A 205/50/16
-Posi-quiet cermanic brake pads
-UR UDP
I was originally thinking I need that brace, but realize that might make it vibrate more. I think the difference between the AWR, SLS, and SU mount is the surface area of chassis direct connect between the engine and chassis. I know that probably did not make any sense, but lets go on what Maxchao said. With the AWR and SU you have a fully 1:1 connection from the engine to the chassis. So any oscillation can carry through to the chassis. You can try to "muddy" these oscillations with a softer duro. This is like when you shoot a bullet in air vs water, that type of effect. SLS is design is different as you can see. They shrink the amount connect between the engine mounting point and the chassis. So when the oscillation goes to be transmitted it has a smaller area to hit. Also they have the wide base to give support (duh), but it also spreads the small oscillation over a larger area. Think of it as a bottleneck for the oscillation. This allows them to use a higher Duro than SU and AWR with less vibration. So this provides you with less vibration and better response (less engine movement).
Of course this makes it painfully clear that the SLS has more stress on it then the others. So if you have any assembly issues ( weak plate with side, or welding), it will be the first to brake. So when we had the ok welds going on the front mounts, it was not really the design, it was the welder as SLS mentioned. There design, just does not allow crappy produced mounts to last long.
But come on guys you got to be realistic with these aftermarket people. We do not have as large of an aftermarket as Honda. Example of my experience:
Progressive 22mm Rear Sway bar (bracket broke)
AWR Rear Endlinks (thread part bent)
SLS side mount (plate broke)
I completely understand these things can happen, but they are not stock and thus not tested to the nth degree. They really do not have the resources. Soooo what is really important is excellent customer service:
Progressive- under warranty if invoice faxed, or $3.50 each plus tax and shipping
AWR - $13.00 + 9.05 for shipping
SLS-sent out replacement no cost
I would recommend keeping the original part just incase, even if ripped (motor mounts). I really should have, but I thru them out. The inserts are really only going to help if the rubber in the mount is not ripped. On the side mount you can look at it without taking it out, but the front is covered until you take it out. The key thing to understand, which I think you do, you can not complete elminate engine lash without solid metal mounts (not recommend).
If anything, do one install at a time to see how much lash/vibration your willing to deal with.
Magus
i know this is an old thread but, the thread speaks of welding the bolts. which bolts are they talking about welding?
blueprotegelx,
You are a luck man, I just revisited this thread! When you buy the mount from SLS you get the mount and two bolts. The bolts go through the two holes in the mount. This these bolts will stick though the OEM holes in the under brace when you insert the SLS front mount. When you use the OEM bolts, you will notice that the bolts spin. This makes it hard, if next to impossible to tighten the nuts on the bolts. I would not even try to wedge a wrench in there to help keep them from moving. If you do, you might not be able to get the mount out without removing the engine. Also, it will vibrate since they can spin and loosen the nuts off the bolt.
Sooooooooooooooooo, by welding though two bolts to the mount, you can then easily tighten the nuts and have OEM fitment. I have made a suggestion to SLS that they do this to all there mounts before they sell them.
Oh the mount reuses the nuts and bolts off the oem mount. I hope that helps. If not, i will see about pictures once the whether gets better.
not daily driven. i'm in college and the car sits while in school. i know it's stiff and i'm going to have a lot of vibration, but i had planned on getting awr motor mounts anyways in the distant future but i ran across this from forcefed for half the price from pg. i've just heard that awr is the best and i had a friend who had awr mounts, not sure what the duro was.
If your looking for the stiffest mount, they sure are the best. If your concerned about breakage, I have heard stories about AWR breaking too. Though I would not worry if you check your car from time to time. I had a broken side mount and it was fine for a time (didn't even know).
As for the mounts, if you plan on driving this anywhere other than the track, do not do the rear mount. It's a pain to get to and install. Plus since the other mounts are keeping the motor very little ability to move, the rear will give very small returns (unless your hardcore racing).
Oh, and I can not argue with half off! (cool)
If you continue to work on the side mounts and choose there inserts, make sure the mount's rubber is not ripped already or there is no point of the insert.
I'm still running my stock mounts and i'm over 111k. When I do change them I will probably order the SU ones. I've only had wheel hop once, the other day actually, I was slipping on a little patch of ice taking off at an intersection. It will happen a lot if you try to overpower taking off without feathering the clutch. She's a finicky beast to be sure, just gotta learn her favourite kinks to make her run smooth. I find though if you do tend to be a lead foot type of gas person taking off from second helps with the wheel hop maxchao.
Wheelhop is cured by stiff mounts, if you still have some slight hop, change tires. There are some tires that have that ring protection...this will feed some hop to the scenario.
One of the problems in the protege is the rear mount placement (other G trans are placed elsewhere, closer to the shifter arm), I had AWR front and rear and I broke the transmission once (rear bolts) because of some side to side movement caused by the stock side mounts.
This is where it should be, too bad we cant modify the location:
Yes, when I had softer-than-AWR SU mount(still stiff) in the front and rear with broken stock side mounts it actually made the wheel hop thing worse, I changed the rear one to new OEM mount and it got a lot better, now with passenger side new OEM it's even better, I'd assume when I put the new OEM to driver side it would fix the problem.
And, it sounds even louder when the wheel hop thing happens if you roll down the window, I would image it's really bad for all the bolts in there. So, don't let it keep on rocking when it happens, push in the clutch and rev up higher and try again...
And it's not really wheel hop...it's the engine and transmission rocking in the bay...you don't hear rubber squeak but metal bumping each other...
Summary, if you want to do SU or AWR, do the other ones before the rear one.
And...any aftermarket would give you some vib and noise, make the not-very-quiet p5 even louder. And for me the idle vib is annoying since it's my commute car...even the soft SU mount.
So I came back to all new OEM but the front SU one...
Josh
