What's this panel called?
eraser851
2008 Mazda 3i
The one to the left of the steering wheel.
And what are some switches I can get for it? And from where?
Don't know how I can be any more specific about it.
Or you mean with what kind of switches I can get with it?
What's available?
i call it a switch panel. idk. i put a switch there for my angel eyes, if u do the wiring you can put what ever you want there. if enough people want, ill wire up my nitrous switch there and do a how to on it. its pretty easy, u just drill a hole in the panel and plug the switch in, i use the cheapo ones from autozone. like 5-10 bucks. lemme know if yall want a guide.
You know I might be interested in an Angel Eyes switch.
ill make a how to this weekend if i can get 3 people to ask for it. its pretty simple, but i work at a dealership and do trim work every now and then so not to bad for me could be different for someone else.
Did your Angel Eyes come with a switch or did you buy that separate?
If so, from where?
ANgel eye how to please
I'd love to put a switch there to toggle angel eyes and one for my jumpered clutch bypass.
when you look in the liittle compartment below the switches, there's a compartment that has plugs or fuses or some kind of outlet on top top of it. WHAT IS THAT?!?!?
You know, I have always wondered that as well.
What is it for? What plugs in to it?
Sorry for the blurry pic. It's dark out and I took it with my cellphone.
That's the OBD-II (On Board Diagnostics) connector. It's an industry standard connector that allows you to read trouble codes (CELs) and also monitor certain engine parameters.
Are there any sort of aftermarket connectors for it?
Say, for example, you wanna see status of your engine on an LCD dashboard accessory or something. :P
there are a couple optoins to plug into the OBDII there is a guage pod that can plug into it and the dash hawk will do that same thing. both run 2-300 and are pretty convienant. you should look into them.
