Becuase I could get the MAF and wastegate for the same price as I could buy a rebuit stock MAF and the MAF has never been used. IT is designed to be used for 300hp plus.
here was Black Zoom-Zoom reply to me:
Background of a MAF:
The MAF sensor determines how much airflows into your engine (using hotwire(I won't get into that)) and converts that data into a voltage signal. It sends the signal (0-5volts) to the pcm, the higher the voltage the more air the pcm is expecting thus the more fuel. Once the voltage reaches 5v the pcm shuts off the fuel supply because in a stock system it should never reach that high and determines there is a problem.
If you want to make more Hp it takes more air. You have to get around reaching the 5v from the Maf.
Want more Hp and accuratley tune it?
To do that you have to increase the amount of air into the engine and be able to register it. This bigger MAf sensor increases the amount of air per voltage. This allows you to accuratley read how much air is getting into the engine, unlike the stock maf which you have to cap the voltage to run more hp(fcd). This makes tuning 50x's easier and accurate. On top of that it gets rid of the honeycomb and restriction of the stock maf.
On top of all that it looks impressive as hell.
I talked to BiggTimm as well:
Also BiggTimm has one by Nick and he said it makes the turbo crazy loud which makes it sound really cool and mean and he said it makes your car sound like it's going to jump up and turn into the hulk and assrape all cars within a 2 mile radius
ok, ok the last part about hulk I added, but it adds to the story... <!-- / message --><!-- sig -->
