What would you want us to make?
I can't believe no one has said this how about a complete engine dress up kit? That would be sweet.
goku4658 said:
would a valentine one fit in any of these din panels that would hold a boost controller or tt?
It will fit any 3 4/16" x 1" device, inside the square, or larger flush rear or mounted front.
Back on the grill topic, i'd like a front grill replacement, basically like what ford puts on the mach-1 mustang, a nice piece of black plastic that leaves it wide open. I hate that black honeycomb stuff thats on the car now.
MSPinVA said:
I agree. Make a deadpedal that looks like the Sparco ones that are in there now.
I"M ALL OVER THIS ONE!!!!!!
brian seriously, i dont think it would be hard to make.
make one that matches Sparco, and one that matches mazdaspeed pedals.
i'm sure it will not be expensive, and u will get a good response.
Count me in on a mazdaspeed matched dead pedal...
isnt the color scheme the same for the 03 - 03.5's (Black/Silver)? That way he'd only have to make 1 pedal...
deadpedal is a hot idea!
and these are the dimensions of the valentine one = <TABLE cellPadding=3 border=1><TBODY><TR><TH>Dimensions:</TH><TD>4.5 in. L x 3.6 in. W x 1.0 in. H.</TD></TR></TBODY></TABLE>
per their webpage at http://www.valentine1.com/specs/....so brian would this fit in your R1 or any of your future projects?
as far as future projects go, if you built one that could hold an Valentine 1, would it be possible to make it so you could shut the door and "hide" it?
I 2nd the idea of the greddy product holder that removes the pocket.
Since you are already making a below the radio holder for the Greddy products, I was thinking about something that you could remove the pocket and replace it with, that would hold either 1 or 2 (side by side) of the Greddy products. I would like to see this since I have the TT and EBC and would like a clean install of them both in my dash.
I'll take a look into doing this on Saturday. Basically, any metal that I use will have to be polished. Regarding making it "look" like the Sparco/Mazdaspeed, that's pretty hard to do due to Patent infringement. I'll see what I can drum up.
- Brian
srd555 said:
Can you do a din panel that would hold two 1/4 din (ie greddy TT and profec B) and one gauge (not sure what size can fit)?
Like this:
Working on a DIN kind of like whatyou have above with 3 52mm's and then one with 1 52mm and enough space for GReddy Profec B2 and latest FATT. I need to get demand here to see which one people will want the most prior to having laser fabrication cuts (it costs a lot you know).
- Brian
Here is the deal. The R1 that we have WILL work for the Valentine one with (one) exception. I will have to customize it a bit as a one-off for you. So, basically, if you are interested, PM me, I'll cut to extend the 3 4/16" width to 4.5", and put felt on the front of it, so all you would have to do is follow my instructions, no painting, slide in and go. There will be at least a half hour labor of $25.00 + $18.00 (part cost shipped). Let me know.
- Brian
P.S. We are doing customs for double din's (2 GReddy products) as well. Done 3 already, looks sweet.
