G geoology Member Mar 17, 2008 #1 Im only hitting 9.5 psi what could be going wrong. any help would be appricated. thanks geo
D dkswim Member : MAZDASPEED 3 Mar 18, 2008 #3 check your clamps make sure there tight. im guessing boost leak. what gear? what rpm? what are you measuring with?
S Sierra117 Member : 2007 Mazda Mazdaspeed3 GT Mar 18, 2008 #4 Sounds like a boost leak, same one I have. Check to make sure all the clamps on your boost tubes are tight.
T trufanatic Member : 2008 Red MS3 Mar 18, 2008 #5 check for boost leaks, if you dont have any mods what so ever and your boost comes in extremely slow that means your turbo is gone.
T trufanatic Member : 2008 Red MS3 Mar 18, 2008 #7 and also if its extremely cold where you are the car wont boost 15psi.
G geoology Member Mar 18, 2008 #8 gpt it figured out the o ring on the adapter plate wasnt sealing, put the factory bypass on and it fixed it. thanks for all the responses
