What should I do?
Just bought the accessport and per cobb due to my mods they've got me running a 91 safe mode map with stage 1/2 mods. Seems at higher Rpms I'm still running lean. I can't currently afford a hpfp. Mods are Cobb intake corksport cat back exhaust and a race pipe/test pipe. Would I be best off removing the race pipe and running a stage 1 map? Thanks in advance.
I'd suggest a flash back to stock map until you can buy the proper supporting mod (HPFP), especially if you feel you're running lean. At least make sure you're using the AP to monitor fuel pressure.
