- P5
Shift to a lower gear as you slow down (this revs the engine and turns of the injectors...if you put it in neutral the injectors will use gas to keep the car at idle)
Seriously?? I always equate the lower RPMs when in neutral to better MPG...damn, maybe I'm ASSuming too much.
I've also read that keeping a clean car actually helps (albeit minimally) b/c of wind resistance - cars are designed and tested w/a clean, slick surface...a build up of gunk, dust, pollen, etc. reduces the aerodynamics of the car. BS?
