what is our msp offset? need asaP!
Where did you get your spacers from? I'm getting ready to mount some +48 Slipstreams and I still need to pick those up. Good to know you have no rubbing.
Got them locally, they were like $30cdn for the set. My center caps kept popping off due to the cap on the back hubs, last thing I needed was to lose a $45 center cap.
Just to give me $.02, I run a 45 offset wheel with 225/45-17 Azenis and I rub in the rears when I go over bumps or have people in the car. Azenis tend to run wider than normal tires, but if you run a stock tire size with 45 offset you should be fine.
