Anybody with 17" stats?![]()
Just from what German TV accepts its 7J x 17 ET45.
Since I'm from same country as majki (CZ), I have yet to test it. From my calculations (Link for spreadsheet) the best will be 215/35R17 since it has almost the same diameter as the rest of tires majki mentioned - therefor speedometer values should not be affected.
(Bad is that I need to go thru a special procedure to add this into my Mazdas Certificate Registration so it is legal in CZ.)
215/35?? Man, the vehicle is going to be really hard and "absolute". Do you think that this is the best idea for such a car? I don't know what is the quality of the roads in CZ but here in Athens, Greece, is really bad. I have 45 tyre profile and I really hate going over bumpy roads.
6J x 14 ET45 175/65 R14
6J x 15 ET45 185/55 R15
6.5J x 16 ET45 195/45 R16
6.5J x 16 ET50 195/45 R16
17" are not allowed
17" are not allowed
FWIW, I stuck my Miata 14" x 5.5" daisies on the 2 the other day while I got my tires swapped on OEM rims. Rears fit fine. Fronts hit the caliper bracket and need a spacer. And boy do they make those front disc look HUGE!I'm thinking about looking into 14" winter wheels and tires, usually go down a size and thinner for better snow traction. I noticed that Majki showed 6J x 14 ET45 175/65 R14 as being available. Just looking at the front disc's I'm wondering if 14" rims will even work. Can anyone confirm 14" rims on the Mazda 2?
Thanks!
