What in the world happened to this 3!?!
whatever it was ...was so high it didnt even hit the back bumper!
it would make a great front clip if you could find one killed in the from for a couple grand. I used to do that at my work. Nothing like taking a sawzall and cutting a car in half (after you rolle the carpet\wiring forward and drop the gas tank\lines of course)
rebuilding wrecks. I worked there for a couple years in Ky and learned alot about how cars are made inside and out. Basically on the floorboard we would drill out the spot welds and air chisel them apart and slide the new clip into it and weld all the way across which offers more strenth than factory. I did Front wheel drive cars only (lots of neons, cavaliers, sunfires, and olds achievas), as RWD would be even more work. Basically you could buy a front hit car and a back hit car alot cheaper than it would be to buy a front hit and buy all the parts you need. Mind you this was in Ky and southern folk are more apt to by rebuilt cars (from places they trust).
Looks like it got mounted from behind by a horny Semi.
I guess it could be rebuilt as the first half sedan half hatchback version of the 3. A hybrid if you will.
Unless you found a destroyed front end car that wasnt rolled for cheap, there is no fixing this thing to save money vs a new one. This thing deserves to be in a junkyard not a rebuildable lot imo.
