what hoes is the one next to temp sensor?
Mazda Pro
2003 Mazdaspeed Protege 2.0 Turbo
found a hoes thats burned up by it leaning on right side of the block/valve cover it is conected on top of a housing i think it is. right after the temp sensor and leads to another that is shared with a bigger one. there is coolent in this line now i looked at manual and could not find a layout of what it is called under heating and cooling system. now if im wrong please correct me when i replace this hoes give her a 6hr cool down take off temp sensor to release pressure and bleed out system?
Your description isn't great, but I'm guessing you're talking about your IAC valve hose.
Sounds like the TB coolant hoses, a picture would help. If the hose is bad remove and and replace it, no procedure for bleeding out the system or whatever you are referring to.
TB hoes that's what it is 5$ fix with clamp. Yea not the best person when it comes to description
