Lol...I paid $300 to rent the scanner they sell for $250, but I get every bit of it back...and I have had it for almost 4 weeks...
You don't need to rub it in :P
I was at advance auto (in Vermont) a few months ago with my brother to buy some struts and the guy had no problem lending us a spring compressor for 3 months(!) even after we told him we were going to take it out of the country.
are these tough to put on? i need to order some and change mine out to get rid of rainy day squeaking.
It's a really easy job. I'd recommend removing the cruise control actuator (2 10mm nuts) and moving it to the side for easier access to the alternator tensioner.
You must be careful not to over-tighten the belts as that can cause premature bearing failure, amazon has belt tension meters for $20.
im sure autozone will let me rent the tool for that.
anyways i just ordered 4 new motor mounts off ebay to put inserts in. cant beat getting 4 mounts for $117 shipped! CheeseHelmet, when i get the box in i can weight it and take the dimensions to see how much it would cost if i bought you a set and then shipped a set to you in canada if you want. prob less than that outrageous $225 or whatever for shipping from the ebay seller
Hah, no need. When I order stuff from the US I have it shipped to a forwarding company so I don't get ripped off on shipping. Also, My mounts are all good except for my passenger one (which I just ordered from rockauto).
Thanks for the offer though :)
Do you have a parts list for the Oil System..someone told me you did...forget who...what about the stock MSP Oil Cooler, I have heard good things about it...
I heard good things about the stock MSP oil cooler too, but I went with a Setrab. Something is better than nothing.
Heres the list. I will PM it to you too:
oil system parts list:
-WITH DocB Oil Pump and PRV-
oil filter relocation kit ebay item# 330431388141
oil pressure gauge and sending unit ebay item# 270357091470
oil pump ebay item# 130328449925
stainless steel braided lines approx 15 to 20ft ebay item# 230397537751
4 pcs. AN-10 straight flare fitting sumitt racing part# SUM-220090B
4 pcs. AN-10 45 degree flare fitting sumitt racing part# SUM-220086B
2 pcs. AN-10 90 degree flare fitting sumitt racing part# SUM-220087B
oil cooler (Setrab is the best brand for the money) ebay item# 270575771116
FRAM part# PH8A oil filter (AutoZone or WalMart)
AN-3 turbo oil feed line sumitt racing part# EAR-63010148ERL
restrictor pellet ebay item# 220599799353
turbo feed fitting at relocator 1/8' NPT to AN-3 Flare sumitt racing part# AER-FBM2000
AN -10 turbo oil return line (use the left over from PRV)
AN -10 turbo oil return fitting at turbo sumitt racing part# SUM-220086B
AN -10 turbo oil return fitting at oil pan sumitt racing part# SUM-220086B
AN -10 oil pan fitting male weld in bung sumitt racing part# SUM-220062
-WITHOUT DocB system-
tee adapter sumitt racing part# EAR-991701ERL
coupler fitting to adapt tee to engine block sumitt racing part# EAR-991101ERL
turbo feed fitting at tee adapter 1/8' NPT to AN-3 Flare sumitt racing part# AER-FBM2000
Water Feed System
-Including throttle body-
AN-6 braided hose from water neck to turbo top sumitt racing part# SUM-230610 (10 foot length)
AN-6 braided hose from turbo bottom to throttle body inlet
AN-6 braided hose from throttle body outlet back to water neck inlet
4 pcs. 1/2" hose clamp with end RUS-620193
2 pcs. water fitting banjo style at turbo ATP part#ATP-FTG-004
vacuum nipple for turbo wastegate/ boost controller
From ATP turbo:
FTG-QuickTap-CompHSG
Code: ATP-FTG-010
well since cheesehelmet wanted pics of my interior, i took some today, not the greatest, but u get the idea
front two pillars are new fabric already
and new sticker i put on today lol
I would like that decal a lot more if I haven't seen it all over the Civic forums...something like that is definitely not original at all IMO...
Damn that looks pimp, Thanks!
you have that exact model? hell for that price i mite even pick it up if it works decent enough
I have one that looks exactly like that except it doesn't support the CAN-bus protocol. It works great, you can read/erase codes and check the status of your various emissions-related monitoring systems (no real-time monitoring though).
P01072 bank 1 too rich....
Got that right. Haha friend had a code reader, the good one that tells you what's wrong.
Also got new ic pipes and an ic core.
