- 92 & 16 Meyatas
No sweat, though that would be helpfulSorry about the damage
ya, bites but what are you going to do....(dunno)..it's just a car, it can be fixed!
(thumb)You certainly have the right attitude when it comes to this.Good outlook to have.
OVERHEATED. (notcool) Doing some searching now to narrow down my troubleshooting. Radiator / overflow is full - no leaks or cracks anywhere. I've only got 45K on the clock but I'm quickly guessing the thermostat or water pump. Feel free to chime in if this is a known issue ...
Thanks a lot. This gives me a good idea of what I'm dealing with (rockon)
well, i didn't do it, but someone at my work customized my drivers side fender, right on the lip....(pissed)
looks a lot like what someone did to my car earlier this week, except mine's a bit bigger and on the driver's side rear fender/bumper - stupid asshole, not knowing how to park (rant)well, i didn't do it, but someone at my work customized my drivers side fender, right on the lip....(pissed)
sorry to hear that Patrick... did you catch it right away? Hopefully you can find the problem and remedy it easily and cheaply.Bala de Plata said:OVERHEATED. (notcool) Doing some searching now to narrow down my troubleshooting. Radiator / overflow is full - no leaks or cracks anywhere. I've only got 45K on the clock but I'm quickly guessing the thermostat or water pump. Feel free to chime in if this is a known issue ...
OOOOOooooo good choice! What size did you go with? I'm really torn between some 17x7.5 RPF1's (15 lbs w00t) or some 16x7 Gram Lites 57c's. Do you think 225/45R16's on a 16x7 wheel with a +46mm will work (I wouldn't mind rolling fenders). I really want something wider than 215 and unfortunately for 17" the next size up is 225/45 which is probably way to big (and heavy!).
Unfortunately I've only been able to find the Gram Lite in +46. Anyhow, aren't the RPF1 16x7's only +43? That's all I've seen of them (according to AutoRnD). I'm really trying to find a nice (decent quality) 16x7 wheel with a +48 offset so I can run some 225/45's without much problem. I really don't want Rota's. I wish the 16x7 RPF1's came in +48...16x7
That 225 should fit, get some decent negative camber in the rear and roll the fenders. Also get a higher offset (maybe +48/50) if you can. Stiff spring rates are also very helpful!
You're on the right track Bala. If the fluids lvls are fine and you don't see any cracks. I would be willing to guess its the t-stat.
yeah i had fun with my UDP back when i got it installed, brought it back several times for squealing. during the winter, i still get some squealing on a cold start but it goes away. u have to play with it and make tiny adjustments at this point. my mechanic was afraid to over tighten and have the belts snap, so he just kept slightly tightening until we got it right, good luck!! that squeal is loud as hell too, esp. with fans or lights on...wake up the whole damn neighborhoodwell i tightened the belts again and it stopped squeeling for a little while but now it started again once i left my g/fs house on a cold start.
how tight is too tight on the belts? someone i was told a little less than 1/2 deflection and that is about what they are at.... they are new belts but should they need tightening this often?
bothas is or stock?
