i had a ?. a while back there was talk of alternatives to a big brake kit. i know you can swap to the msp brake set up: getting new calipers and rotors and pads, but i also thought i heard something about maybe the 6 cause they would bolt up the same and those rotors are even bigger... is any of this true cause i am tired of looking at these elf size brakes through my wheels
6 brakes = MSP brakes in the front.
i just removed the vtcs and port it... but i dont feel any difference!!
could it be because i have cheap unknown cai??
All CAIs work the same. They're just a metal tube that directs air to the throttle body.
I thought the MSP rears were the same as the 6's? Either way, you can "upgrade" to any year Mazda6 front brakes with the exception of the newest model I believe. You can even swap the MS6 fronts just fine but you need at least 17 in wheels I believe. They're still only single piston calipers but it's something like a 12.2 inch rotor. The regular 6 front brakes were also increased in size for the 06-07 model years (or is it 07-08?) and they will fit under 16 inch wheels. I'm considering the latter when I get my 16" Volks as I'm pretty sure they're larger than the MSP fronts.
I wasn't absolutely sure about the rears, so I didn't confirm it.
yeah i want to allow my stocks to be able to fit when i swap them out occasionally. the bigger ones would look alot better with the 18's though. so i just need the calipers, rotors and pads and change out the brake fluids...
Quick question.
Which for the high beam is teh pos and neg? Both wires are black
Digital Multimeters are your friend. I never do an electrical project without one.
Just talked to the mechanic. I am leaking coolant inbtween 1 and 2 cylinders, but he won't get to tear it down till monday, so, he says i should be ok to drive, but i need to get it to him Monday.
Also, he recomends putting my stock header back on so i can plug in my 2nd 02 sensor, so there is one less thing for them to pick out, considering i've already used up the cost of my warranty.
I paid $1800 for it and have used it for about $1800 total so far, so they are going to start lookin for reasons to deny me
It should all be covered under warranty, so, we'll see.
Hopefully, i have teh car over the weekend adn the motor just gives out totally.
