I, against my own judgement, used the brass nuts that came with the exhaust studs I ordered for the turbo... It was late, I was tired, and didn't feel like looking around the shop for any nuts... Too much heat, too soft of a metal, and the threads just pulled completely away, so now I have a 1/4" gap between the manifold and the turbo meaning I only boost 6psi at about 5,000rpm... So, I get to remove it AGAIN! Yaaay!
Biz, where did you get those tails?
Also you have a clear corner lens on your headlights instead of the stock amber ones, where did you get that?
btw I love how simple and your car is.
Dorman. 03109.Brass nuts huh? Where'd you find those at? I got copper lock nuts from ATPturbo
I love them.
Injector?Ok guys, I need some help. I have a mazda protege that has all the mods that a MSP would have. I am getting a miss on CYL 4 and I can not get it to quit missing. I am getting fuel and spark I also resurfaced the valves in that cyl because I had low compression and I thought where the engine might have set for a long time with those valves open they might have surface rust and are not sealing good. After the head job the compression came up to around 120 I think. It had a SS V1 AFC on it that I have taken off trying to fight this problem. The engine came out of a 626 and I had to change the cam pulley for the CPS so after that it still had a miss and I also changed the crank pulley. IT STILL HAS A MISS AND I CANNOT GET IT OUT!!!!! It is making me so mad I really don't know what to do, if you all have any ideas on what might be causing the problem PLEASE let me know.
Smoke test it?gasket?
Hammer time?Grab a hammer
