I bought a CSF JDM Radiator from Manny at TBK Performance in Miami. It was pretty reasonable. Ask him where he got it. It's definitely cheaper than the corksport.
I have a CSF now from radiator express. it was 145 (i use a pro5 one), but im getting a hookup on the corksport one so itll be wiser to get that one. plus its purdy. Thanks for the tip though, if all goes bad and i cant ge tthe CS one ill ask manny
dont ever ever ever ever ever ever ever ever ever use rad leak stopper. period.
if theres a leak, find it and get it fixed.. this s*** will only make OTHER things worst.. and can clogged up the turbo cooling hose and the heat exchanger in the dash board..
find the leak and fix it.. there is no compromise for that.
yea after i read the can i was like ehhh no. i thought it was just used for the rad, like u apply it to the hole, or it bonds to the metal in teh rad (like take it out of car and apply it).
id never use that crap now that i know how it works.
All out detail for me today. Buffed and glazed the paint, waxed the wheels and completely cleaned the interior.
They do have radiator sealent that's like a putty that come's in a rolled up piece.that is pretty good to fix a cracked radiator endtank with....
x2 havent seen lara around for a very long time probably since the first mazdapalooza
I've been "away" for about 2-3 years I think. I've hung out with the SU crew down here in FLA since I moved back from NC. Alots happened and well, here I am again. I'm sure I'll be lurking around more often. Looking forward to going to a few local meets this year and probably the next summer palooza. Hopefully there won't be any car gremlins out to get me before then.
But I have to thank ghost for coming over to help me today with my NRG ground wire install. The car definitely runs smoother at idle. :) I owe him big time.
yaaaa, go su........
Finally after ~4 months I can say I did something constructive to the MSP, installed new RR Racing Inserts in the Front and found that my back end is stagging way too much for my liking .
Also am finishing off my P&P IM, should be going on early spring
Fixed a slow leak on the radiator, the return hose clamp had loosened up a little bit, probably with the vibrations. I'd been smelling coolant for the last few days, but didn't pop the hood to check, resevoir was just dregs in the bottom. Filled her up, tightened up, no smell anymore.
Always something with this car.
i bought BridgeStone Potenza RE050A Pole Position Tires, they get to the shop on wed. cause they only had 2 in stock and need 2 more
Bumped my boost back up to 10psi today for the first time since selling my secondary injector setup. Still retarding timing with the MPI, but it has no control over the fuel system.
Holds a perfect 11.5:1 AFR, and the car absolutely rips. (rockon)
you don't need a whole new tranny for a broken lsd...
i know but those lazy fuckers dont want to pull the broken lsd out and put the new revised one in there, so they gonna replace the whole tranny. which im fine with a fresh tranny
