stripped off the subframe for some blasting and painting and stiffening. Clearly the underside needs to be cleaned up to look nice again. 10 years of wear isn't pretty.
and positive that the trans mount and rear mount are good right? thats really the only other simple solutions i can think of. just the little things before trying to dive into something big. it would suck having to take out the trans. and rebuild.
I have solid mounts all around, they don't allow for any play.
I get an annoying rattle from my shift knob when I'm in gear. How hard are those bushings to replace?
The rattle may not be coming from the bushings but they are easy to install. I got the 3rd link kit which is nice to have but wasn't really necessary since my stock bushings weren't that worn. And the other bushing they sell for the shift stabilizer bar may not be necessary, the stock bushings don't really have any play as it is.
The rattle might be from the little circle piece that is part of the shift boot. Mine rattles. Well eveything rattle when you have AWR mounts :)
mounted some probe gt swirlies for winter (I know they're backwards) I didnt feel like taking the tires back off and mounting them the right way
Getting two new BFG Gforce sport comp2 installed today, need to get my coilovers or buy some new struts and springs asap because my tires are getting ruined by the alignment.
I took out my condenser because it was damaged and didn't feel like buying another one at the time, so I just left it out. Everything else is still there if I decide to buy another condenser. It's fall and temperatures are cooling down, so I probably won't get one until at least next spring.
I have 2 laying around if you want a cheap one.
Going to a local, weekly meet tonight and might put a 'FOR SALE' sign on it and a list of mods to see what kind of interest I might get in the car...
Trans finally crapped out today. It is stuck in 4th gear and I can get it to engage 3rd but not any other gear. I'm thinking the shift fork came loose or is bent but I won't know unless I pull the trans.
well i attempted to fix a rattle that has reared its ugly head since i installed awr engine mounts. loud rattle around 1500-2000rpm from the pass front door panel near the speaker grill. managed to make it slightly more tolerable but got that nasty stick black crap from the door panel on my window =(
