- MazdaSpeed3
good s*** kyro..!!
Thanks man, I did it on my car a month or so ago. Now I have two "appointments" set up for Fri. One is for a reg 3 gen uno and the other is for a Mazda tech's 1st gen MS3. I can do it by memory now, lol.
good s*** kyro..!!
^ Right there.
Screw the pics, give it a couple weeks, and if you dont get random instances of them turning on,... i want to see the hookup
I used this one instead. It works on both Sport and GT. I have installed on both models. Same wires and everything.
http://www.mazdas247.com/forum/show...ing-a-wire-through-the-firewall&daysprune=100
How can that work on the GT? The GT has OEM HIDs and that walk-through does not work with OEM HIDs.
I used a walk-through very similar to this. No problems on my MS3 GT with OEM HIDs. I've had the modification done for over two years now.
if u follow the walk through it would work perfect. i have a speed 3 GT and the mod works just fine. and u can turn your fogs of and on when ever you like. i have 3k hids and im lovin them
And HmG_mS3 has also performed it on his GT and this is what he said.the wiring is the same on both gt and spot. the only difference is that the gt has hids in place of the regular bulbs.
i looked at all the wires befor i started and all the colors were in the right place. so i gave it a try and they work perfect. i wired mine to the ACC so i can turn them on when ever i have the key on. =]]
So all in all, for you own clarification, and it's something I still do when someone asks me to do their car. Check the wires.It works on the GT models also... so whoever is wondering
if it works or not on the gt model well im telling you now that it does...!!!just follow all these steps and you shouldn't have a problem..!! THANKS....
thanks again Kyro. its a nifty mod and should have come from the factory like that.
Hmm, interesting. Thanks for the clarification. I guess the initial post in that thread needs to state that you can use it with the GT, as it states otherwise.
