eric, click the vimeo link......
and anthony, that pic sucks. you cant see my car in the last bay
Best one I got, homie.
okay i looked and looked at this. Its not brain surgery, no blood, and probably not soldering...![]()
oakland i am not sure that the dry filter are cleanable/reusable. Maybe a gentle blow from an air gun from inside out would be best 20psi or less. i could be wrong but i dont want you to mess up anything especially that maf sensor !! they are not cheap.
also do you use a MAF cleaner when you do filter maintenance ?
i have a 07 ms3 and am experiencing some problems not sure if turbo is ready to take a s*** or what i can not accelerate properly after shifting with out the car boosting like crazy i will shift in any gear and the psi will shoot straight up to 15 like if im flooring it and i barely press dowm on the gas any ideas what it might be
I'm not following you. Are you on snow tires or something? You're saying boost hits instantly with you barely touching the throttle?
Panasonic stock battery dying on me today. AutoZone said it is rated at around 250 cold cranking amps I belive. Three years of usage at 29000 on the odometer sounds about right? I replaced it with a Optima Battery 35 redtop with 3 year warranty.
