rodslinger
Something about an angry snail under the hood perchance? Didja have to do anything silly to get through the test or did it just pass as is?
Yeah that thing plays hell with the OEM emissions. I was able to get it to pass with no special hacks or mods. Just installed a highflow cat in the downpipe and worked for a few days on the tune to get it right. The downstream sensor was the biggest hurdle. It needed to see the A/F ratios in a very narrow range to not throw any catalyst efficiency, slow response or lean/rich codes. I also backed off on the wastegate tension a lot so it isn't really building boost in normal driving. At 1/2 or more throttle it will start to build about 2psi at 3.5k rpms, 3psi at 4k and ramps up to a full 8.5psi around 5k and up. Helped driveability a LOT. Now if feels like a regular 5 unless you get in the gas and then it goes like hell. Feels about what a factory turbo setup should.
