- cx5
Xwedge.... those look great! Where did you find/get them? How much? How long did you wait?
Finally received my low profile headrests.
Put new wipers on mine, too. Got really annoyed with the OEM ones the other day. I've done the Bosch on my last car, wanted to try something different this time. Pleased so far. https://www.amazon.com (commissions earned)
What is a 407 ETR? An EZ Pass like thing?
https://youtu.be/PRSoRkM8GcMIf someone has no experience whatsoever in cleaning engines, I would watch someone do it. A pressure washer can cause quite a bit of damage if one is not careful.
But you can eat off it...man (you're right though)!!!That's a lot of work lol
Sorry if I caused confusion by saying a steam cleaner is like a pressure washer. It's like it in the sense that it uses water and it "sprays" the steam. It uses heat rather than high pressure.
Chris, what happened to the alternator? How many miles do you have?
98500mi, not sure. Won't charge the battery. No noise I could find, might be a bad voltage regulator. Started intermittent then completely went over 2 day span. Hopefully it's not a wiring issue. Driving my moms beetle in the meantime.
The voltage reg is built into the amp. *edit the starter fuse is also the amp fuse, and the car starts just fine (of course it became crappier as battery discharged)... realized something was odd when I didn't see an alternator fuse, so I checked the service manual and its under "STARTER".l it's pretty much an alternator issue or harness issue.. but seeing as it started as intermittent battery light and some 13+ voltage to no chargojg voltagr at all, I'm leaning towards alternator. Couldn't fond any obvious bad wiring or grounds either.Regulator or a bad relay. Hopefully they can track it down rather than throw parts at it.
