What Exhuast upgrade u got????
The HKS still isn't as bad as the OBX and the greddy. The low angles make it look much larger, it's not that bad. I al;so found that putting some steel wool in the silencer quiets it down evern more. My car is really quiet with the silencer in, even with header and 1 cat removed.
here's the Vibrant, sounds near stock with the silencer in
From the side the tip sticks out perfect, and again the sound is great
I have a ractive header, 2.5inch straight pipe to a tanabe muffler. I need the silencer in at all times..... it is overly loud otherwise. :(
if you don't want a loud muffler pick up a Racing beat cat-back off some MSP member. You will just have to get a little chopped off the tail pipe and re-welded to make it not stick out so much. wish i had about an inch more chopped off mine. might get that done soon.
you probably can pick up the axle-back section pretty cheap off a member....
-ryan
I had the MSP aftermarket exhaust on before the MSP factory.
I had to have it chopped becasue i had it on my sedan before i got the P5.
It was pretty loud like a lot of other aftermarket exhausts and very droning above 3K. i finally had to swap and i love the factory MSP exhaust with my SRI intake........had it on for like 3 years between both cars......
I would recommend the Megan catback.It's a 2.5" system and sounds really good.I have had it on my red P5 for almost a year now.The best place to buy it from is Altered Motorsports.His name on the board is AODfan
Hello to everyone, I am new. I have the Team Moon 2.25" cat-back exhaust. I have not found anyone else who has it. It's not stainless, it's aluminized steel. I have had it for a year and a half now, rust is not an issue on the piping or the muffler (which is stainless steel). The flanges have a bit of rust on them, not bad though. I got mine for $300. Nice deep sound. It does resonate pretty badly inside at highway speeds though. But I don't care. On the dyno, it gave about 6-7 HP for an automatic car. For a stick like mine, it might be 7-8. Not bad for an el cheapo exhaust. I will probably check out the OBX 2.5" when I go turbo.
Wheres a good place to make a Racing Beat exhaust purchase?
