What does this light mean
styles_t
Mazda 3s 5 door
there's an yellow light where the rpm's are the stays on when i turn the car on - i had the car for 4 months and this is the first time it turned on - what does this light mean
i have a mazda 3s 5 door
can someone help me out
ohhhh i also changed the oil like 2 weeks ago so i know its not that
tire pressure? really because its where the rpm's are at under the oil light. But the oil light is not on, its the other light thats on and i dont think its tire pressure
i';d go outside and look at my dash to see what ur talking about BUT.... my car is gone :(
Power Steering i think
nope its not power steering either because its not the little yellow wheels thats showing - its the other yellow signal, it must be the engine light i guess but what can be wrong, its a brand new car
does the bad crash sensor set off a cel? also it's common to throw a random cel on brand new mazdas but still get it checked out...is the light solid or actuly flashing? If it's solid drive to dealership but if it's flashing tow to delership.
the light is solid - and the dealership i bought the car is in NJ but i live in NY
why the hell is that light on - what can possibly be wrong with the car
find dealership # and call for an apt cause if you just show up you will be there for a lil bit. after calling eat breakfast if you already havn't and take it in for a check...also see if they can get you a pcm update (naughty) Mazda relases updates but won't tell the dealers what they fix...
*EDIT* Don't go all the way back to NJ...find a dealership where you live(lol2)
your cars manual will have a picture of your dash with names and meanings of every light on your dash.
Take it to the dealer
I agree with DA 6- take it to the closest Mazda dealer. I bought the same car (Mazda 3 Hatchback) in June and the check engine light came on twice. There was a problem with the settings and the dealer was able to run some updates and take care of it. Since the car is brand new it will still be under warranty so you won't have to pay.
i had my check engine light come on recently, i took my car (3 hatch back) to the dealer, and within a few hours, i had it back. the dealer said that it was the purge valve solenoid that went bad. and as for you not knowing what light is on... it's common sense, look at the manual.
