Maxx Mazda
Contributor
- Stock P5
If the belt broke the car wouldn't run at all...
New engine buddy. Just find a used engine and drop it in, cheapest way.
Thanks. See post #25.drgnzadiel101 said:How did the engine oil get inside the cylinder in the first place? The car has many seals, gaskets, and O-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plug, it will cause a misfire (engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder. "
I got my car back! The new used engine seems to pull better than the original.
I got the piston back that got a hole in it and one of the valves. It's messed up! I'll post a pic as soon as I can.
Does anyone know what the normal compression ratio is for the 2.0l engine?
