What could we make for you?
who not rockers
brian
about the fakeout swtitches panel. could you make one for rocker switches tho. these switches there are needed. i have a foglamp switch there and mydimmer switch. I also have my gtech and radar detector hooked to a switch there. it would all look so much cleaner with a nice bracket. even thought im good withthe wiring for it all i can dremel a bracket out for crap. i need you help.
silverspeedtim said:
brian
Here is the deal. If demand is high, I will make a metal plate for a GReddy product. If the demand isn't high, then I will probably make a few ABS plastic 3/16" plates and customized it accordingly. I have all the material, and will attempt to do it this weekend (barring time). Therefore, I can make you a one-off plate with holes in it for your choice of rockers, etc.
Remind me in a few days and I'll have something for you.
- Brian
03MSP-Brian said:
Let me know about the front guys.
Regarding the rear for sedans, I just drilled two holes and used hex bolts/nuts up top and foamed the back of the plate. With my old P5, I did a custom back plate, screwed the license plate as normal through the top holes and on the bottom I had reversed the screw/nuts to hold the bottom and that worked.
Let me know "exactly" what you want, and I will make it and get it cut via laser.
- Brian
Brian - Check out my post on modifying the original rear bracket...if you want I'd be happy to send you more detailed pics if you want to use them as a pattern. I'll see how I like mine as I haven't driven with it yet, but don't expect it to rattle or anything.
If you could design a front and back bracket that hides behind the plate, and make it like $50 for the combo that would be sweet!
Here's the link: http://www.msprotege.com/vbb300/showthread.php?p=931198#post931198
Ahhh, I see how you did it - nice, though it looks like some I've seen in Murray's Auto Supply. It basically is a "I" bracket that you screw to the car and then at the top of the I, it is raised a bit (because of bolt), and you screw standard license plate into that. I've also seen universal brackets like this.
Hmmm, I don't have a P5 anymore, but may consider this idea. Price around $50.00 doesn't sound far off for a pair (front/rear).
Who is interested, start a list...
- Brian
- Brian
1)MCSTARK -- I'm in..with one suggestion: make it so you can attach the license plate with four screws, instead of just two.
Yeah...my mod is not the most elegant thing, but the plate covers it, so it doesn't have to be pretty. I'll post my "how to" in a day or so, and maybe that will give you some ideas for the design.
Do you work in a machine shop for a living...or just on the side? Hehe...nevermind, I just checked out your website...I shoulda stuck to my guns and went for engineering, oh well....
Another product suggestion...a glovebox organizer. I saw another one online, but the guy never came through. His was $35, from overseas, and cheap plastic. I hate having all my crap stacked together.
You could make the middle compartment big enough to carry CD's -- that would give the "legs" a wide enough stance to be stable.
Here's a quick drawing I did to give you an idea...
Sorry, demand is not high. We work with metal only as of current.
I would like to second/third the clear bumper lenses. I know you can use Celica or RX-7 lenses to replace them with some modifications. I do not like the look of these all that much and am afraid of doing these mods, especially the RX-7 by using a dremel tool. I think the same lense but clear would like exceptional. I heard around that you can actually make the orange coulored ones clear soemhow, although I dont believe it totally. I know this must seem minor to some of your other requests but I would appreciate if you could consider this.
