Weirdest radio problem - only CD player and volume work
whalleyboy
Mazda, Proteg5
So the other day I left the lights on (aftermarket remote start kept the car on until after i got out so i couldnt hear the beep) and killed the battery. No big deal, I left it for a day and then jumped it with my other car today, no problems, except now the radio basically doesnt work. The volume knob and cd player work, but I cant press any buttons (power, fm, clock, seek) so all I can do is turn the cd thats playing up or down, but I cant even change the song..
Any suggestions? I'm going to take it apart this weekend probably and maybe test replacing the fuse?
if it is getting power (and it is) - the fuse is good.
Sounds like the radio has failed.
Remove and replace.
Thanks for the diagnostics pcb!
Late reply, but I didnt end up needing to do anything. 3 days and about 4-5 trips later, the buttons just started working again.
OK... You've got a gremlin then....
Your car may still need to be de-hexed...
You should give ghost busters a call... Or sprinkle some holy water on the dash...
