Weird problem 2010 Mazda5 error code U0101 and a few others
rat240
2010 mazda5
Having the weird problem it all started yesterday i went to start the car as usual but this time the traction control light stayed on along with the check engine light and the AT .
The gear pattern on the cluster did not light up when i selected the gears. The transmission was stuck in limpmode from what I've seen online it stays in third gear and shifting to reverse is a bit rough .
Later that day the transmission went back normal operation the gears were displayed once again on the cluster and everything felt normal but the check engine light was still on and the traction control light.
Today all of the problems came back i cleared all of the codes and still nothing has changed
