black-3-knight
- 2004 Black Mica Mazda 3s
i have the answer
i also have a black mica 3i, and have used several waxes and polishes, including the expensive ones at work, (im a car painter). the only one that i really liked that left no haze was 'Eagle-One wax-as-u-dry', comes in a translucent red bottle. when you wash your car use an eagle one soap, (most waxes go hand in hand with a soap of the same brand), wash your car, before you dry spray the wax, you dont need much just a spray or two on each panel does the trick. then just simply dry it all off. if it does leave a haze which it sometimes will depending on the temperature outside, just get a clean dry terry cloth or chamois towel and wipe it off. trust me it works. let mew know how it turns out.
black-3-knight
black-3-knight
