Water pump
JasonBourne
2003 Mazdaspeed Protege
hello everyone, can anyone tell me if the water pump of ours MSP is the same of the regular protege??
(hand)
Yep...not too bad of a job. Should do your timing belt while your at it. Oil pump wouldn't hurt either since it'll be easy to do.
You gotta pull valve cover, timing cover crank pulley timing belt then water pump. You may as well replace at least the timing belt while your in there. Oil pump would be a good idea too
