S streetglide007 Member Jan 17, 2011 #1 washer fluid not spraying. Front or rear bottle is full, fuses are good. Tried to listen and feel for sound/ vibes from pump or pumps. nothing . Any help would be greatly appreciated.(screwy)
E erhayes 2025 CX-5 Turbo Contributor Jan 20, 2011 #2 Check to voltage at the pump if you can. Could the fluid be frozen?
R Ra) Member : Sexy-7 Jan 23, 2011 #3 for the mk1 there was a Mazda TSB about changing G-motor to EG-motor(enhanced?) for cold areas
