wanting an aftermarket turbo manifold
Status
Not open for further replies.
I am using a split second tuner. I don't know how to use it I would like someone to teach me cause this car is my daily for now. I love the car I just want to build it correctly. If I get my bonus check I will build a new motor that's completely forged.
x2 ^^^^^^
I see you are from Chandler. I live close to Tucson.
If you are dead set on a mani, I have an extra Manifold that I purchased from someone on here a while ago. I can not recall what it is at the moment, Maybe a Hi-Boost mani. I will post pictures when I get home in about 3 hours. Will require a different turbo I believe.
Where do you live?? We should meet up I would appreciate someone who actually knows about this car so I dont f it up
Yeah, I would be real careful with that turbo on it even at 8lbs without a good tune..... These cars will blow up on 10 psi on the stock turbo so just a word of warning.
I have the stock supermap. That is a good starting point if you are trying to tune your car. mine needs tuned but I just haven't done it yet.
Dang wish you were closer. I just picked up a P5 with a hell of a lot of mods including a Split Second, Brand New Wide Band setup. Used to belong to a mamber on here, great guy. I would be in the same boat as you with the SS though. Going to use that for my MSP project I have going.
Well I fixed the manifold myself. But in the process I found out my turbo was bad and how rigged my car is. Fixed most of the issues went through my stock on turbos and took my original and another turbo to make it work. It now boosts quicker and is running more efficient. Stuck a my buddies wide band on it to see where I am sitting and its doing perfect numbers.
Status
