ZeroAccess
Honda used the b18c5 in the elise at first, I believe they are using a tuned version of the celica motor.
http://66.139.73.25/elisespecs/index.html
Specs on the Lotus Elise using the Toyota Motor
Engine:
Toyota supplied, 4 cylinder, DOHC 4 valves per cylinder with variable valve timing and lift
Capacity 1796cm3
Bore/Stroke 82.0mm / 85.0mm
Maximum Power 190hp (141kW) @ 7800rpm (DIN 70020)
Maximum Torque 138lb ft (181Nm) @ 6800rpm (DIN 70020)
Compression ratio 11.5 : 1
http://www.import-heaven.net/specs_toyota_celica_gts.shtml
Specs for GTS
Type 1.8 Liter
Cylinders 4
Horsepower 180 @ 7600 RPM
Torque 130 @ 6800 RPM
Redline 7800 RPM
Drive Train Front Engine / FWD
Gear Type 6-Speed Manual
Performance
0-60 mph 6.6 sec
0-100 mph 16.3 sec
Mile 15.4 @ 91.6 mph
Top Speed 130 mph
Gas Mileage 23 MPG City / 32 MPG Highway
Engine:
Capacity 1796cm3
Specs for GTS
Type 1.8 Liter
Cylinders 4
Redline 7800 RPM
Performance
0-60 mph 6.6 sec
0-100 mph 16.3 sec
Top Speed 130 mph
