SixString95
- 2003 Mazda Protege5
Hey guys,
I've got a 2003 Protege5, automatic with the nifty shift gate and "manual mode." Recently, I've been having problems where the engine fires up and after a while the whole car starts shaking. The engine vibrates A LOT. It's not noticable at higher speeds/RPMs, but definitely freaky when sitting at a stop light (the whole car is literally vibrating).
Probably six months ago, I started the car up and the whole engine shook to the point that it wouldn't even drive. I took it to a mechanic, who read the code that had triggered the Check Engine Light. He said it was "Random Cylinder Misfire" and advised me to change the coil packs/ignition coils if it persisted.
Since then, I've only had occasional engine issues, most of which were remedied by simply letting the car sit. It would start up perfectly fine the next day. Now, the car starts normally, but progressively rattles and shakes as I drive it around. Like I said, it's most noticable when at rest or driving at low speeds.
I bought a pair of coil packs and popped them in today, hoping they would solve the problem. I fired up the engine, threw the car into reverse, and before I'd even backed out of my driveway and shifted to drive, it started shaking again. I noticed that it was worst when idling in drive. It didn't shake as much in park or reverse, but there was a noticable vibration.
So, I'm stuck. I'd love to fix this problem myself (without having to pay a mechanic), but I'll do what it takes to get my little P5 back on the road. I've read of similar situations where the problem was a vacuum hose leak, a vacuum leak in one of the cylinders, or something relating to the EGR valve. Any help, advice, or solutions would be greatly appreciated!
Thanks guys for reading my essay!
(rules)
