Urgent Help Needed with struts/swaybar
DrummerJim50 said:
If you can't afford to buy new struts right now, I would just weld it as someone else said. I don't see why that wouldn't work as long as you don't damage the sway bar when you're welding (just weld a piece onto the strut so you can attach the sway bar to it). Put a lot of weld on it and it should be strong enough, as long as you don't completely deform the metal from the heat (which could be a problem).
I thought about that, but the weld would have to be perfectly flat on both sides for the nut and spacer to sit flush against.
"a lot of weld" + perfectly flat = paradox
ddogg777 said:
Peeps, you need to change the heim joints (ball joint) on those Delsing endlinks if you want to preserve your strut brace. You need a heim joint with a high misalignment spacer because it looks as if the links are binding with the bolts. Here's a pic of what I'm talking about.
I woudlike know where to buy those rod end?
how much for those rod end?
thank
seb
Remember, you have to get a bigger ball joint because of this:
"spacers are assembled into spherical rod end ("heim joint") bores to increase misalignment (also effectively reduces bore i.d.).
