thanks for the infovodapas77 said:There's also really no point to driving around with the old IC doing nothing anyhow.
When you put in the new FMIC unless you buy a bracket to replace or a larger radiator, you have to keep the old IC on the car to keep the stock MSP radiator from sliding around because it is incorporated into the design of the radiator bracing. (Taken from the European turbo-diesel 323s)itz_alan said:thanks for the infobut what do u mean by that?
i think the 1.3 bar Mazdaspeed cap is enoughDemonic-Speed said:If you put in a bigger rad will you/or should you upgrade the water pump?
vodapas77 said:When you put in the new FMIC unless you buy a bracket to replace or a larger radiator, you have to keep the old IC on the car to keep the stock MSP radiator from sliding around because it is incorporated into the design of the radiator bracing. (Taken from the European turbo-diesel 323s)
Actually by the looks of it the Ion kit has less distance from the turbo > IC then the wagner kit. From IC > TB the wagner may have the shorter distance. That's what I've have noticed. No arguing over a few inches. Any upgraded intercooler for this car helps out the heat soak issue.MazdaSpeeder00 said:Im not trying to argue or start an argument but Ive heard that Wagners kit is actually a shorter routing of pipe. Still either one is a good kit.. Do as you please and enjoy it.
