SR MOTORSPORTS
I just want to tell you that SR Motorsports has Under Pulley and water pump and alternator pullies. It's 209 for the crank pulley and 199 for the water pump and alternator pulley. They are made by indiglo.
As for a header you can use a 2.0L probe header from Bosla or pacesetter I4 2.0 for 626, probe and mx6.
About CAMS, I forgot who posted this but there are specs for the Speed Channel Challenge Protege. I would on stock MP3 and P5 regrind cams from 380 to 400. Like the BP Mazda Motor you will not need shims or springs.
Later on if you are not going Turbo and want an all motor MP3 or P5 deck the head and of course port and polish. On a 1.8L BP Motor decking .080, port and polishing cost me 650 at a head shop in Maryland. Also I took the specs from Gude along with my friend tomas potter had cams regrind. that was 225 for both. At that time there was no Cam gears for the escort gt/protege 1.8L bP motor so we used the miatas which has a slightly different drop dead center. As proof this June 2nd he ran 14.3 @ 93 MPH and finished second in all motor class. Also we can still put a ten pound turbo kit but we need to redo the valves with titenium valves and put a brace like thing on the lower crank so it does not flex with more horsepower which can be used from the new miata 2001-02. Thats why I hope those cam gears come out soon. I already have a port and polished throttle body from a 2.0 probe which fits but I have to do some modifications for it. Also get those intake thermo things they really do work.
After my warrenty runs out I might drop my 428 Cobra jet Motor in my Protege5. That motor has 850 HP. It was in my 1971 Mach I Mustang. I spent 5,500 just to rebuild the motor. Before I was hit head on it ran a 3,900 mustang 10.8 @ 145 mph
