CaffeineTripp
- 1992 MX3 KLZE
Still haven't figured out what everything leads to, especially the orange wire, as the only orange wire that is in the system runs from the distributor to the ECU.
Further down the line, the black splices to a blue wire, which in turn is connected directly to two other blue wires.
The white/black wire is spliced into the igniter yellow/blue, I believe. Have to double check.
Neither the Chilton's guide nor the factory service manual has these wires listed on the wiring diagrams. Quite at a loss as to what this relay controls.
Vehicle is a '93 MX-3 with the 1.6 SOHC, manual trans, A/C, power steering, bone stock.
