Unichip, Tuned!
silverspeed03
Boost Junky
2008 MS3
Well I installed my unichip a little more than a week ago and was pretty satisfied with the factory tune from Unichip. Running Map A only: Low Boost (stock boost) setting was very smooth, no hesitation at all. High Boost setting was not so good. I would spike to 14-15 psi and then hit fuel cut. So I had a custom map uploaded and WOW what a difference Map A: Low Boost same as above. High Boost is wonderful, pulls really hard at about 4000rpms to redline and very smooth. I love it!!
I had a chance to run my buddy in his STAGE 2 SRT-4 plus Map clamp, upgraded FMIC, and TBE.
We went from a 30mph roll (2nd gear), he got a good jump on me, he pulled 1 1/2 car lengths on me by the end of third. We ran to 85-90mph, at the end he was about 3-3 1/2 car lengths ahead. My intercooler was heatsoaked by the time we found another open spot to run so we didn't even bother, but I know he would have walked me reguardless, but yeah it was a fun and I'm definitely buying an FMIC here soon.
Haha, satisified till you are used to it and want more power. it's an addiction. I need to run a stage 2 myself and hopefully tonight I can run this one.
looks like the only performance mod you have is a chip. is that correct?
His sig:
Boost Gauge - JDM Headlamps - Injen CAI - AWR Front MM - Nology Hot Wires - Kartboy shifter/bushings/exhaust hangers - CS Intake Duct - DGM Lip - Auto Exe Grill - Valentine One - Vibrant Exhaust - Bottom of rear bumper painted black - GT SPEC Lateral Arm Bars - Delivery_Guy Shift Boot - 5/32" Samco Silicone Vacuum Lines - NGK V-Power Spark Plugs (ZFR6F-11) - MOMO Raptor Shift knob - Apex Motorsports Air Diversion Plate - Redline MT-90 Transmission Lubricant - Luminics Titanium White Bulb Series - Rockblocker taillight tint - RX-8 18" wheels - UNICHIP - Foglight delete covers
Definitely - that's exactly what I was going to say.
Upgrade your intercooler! And if you're running higher-than-stock boost, you should change your plugs to one heat range cooler. (ZFR7F-11, I believe. I will be running Denso IK22 plugs in the near future, hopefully.)
I just found out that magnus motor sports is an authorized unichip dealer. I think my next mod is gonna be a chip
Yeah man it's definitely a drug.
I'm stopping till I get another car to start the habit up again. In the mean time this dose should be enough for now.
arent you worried about your internals running that much boost? ive heard of cracked rods @ 10psi. i run mine @ 9 psi with just a mbc... let me klnow if you know heard anything about running high boost like that on stock internals..
People have blown the engines stock. I wouldn't go above 10 psi personally but I would also get the bolt-ons to go with it.
it`s not about "aggressiveness." MAP B advances the timing and is set for race fuel. DO NOT run MAP B without race fuel. someone on the forum recently ran MAP B for a day and blew the motor when he would have been perfectly fine on MAP A. tuning your MAP for a better A/F ratio and advancing the timing are two different things. advanced timing = detonation or race fuel.
silverspeed03 said:
From unichip out of the box, Map B is more aggressive
Custom tune, now Map A is more aggressive
Matrix said:
So Map B has the more aggressive timing, right?
